Simple SS Fret tang jig http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=47932 |
Author: | Michaeldc [ Thu Jun 23, 2016 1:00 pm ] |
Post subject: | Simple SS Fret tang jig |
Hi all, Here is a jig I came up with for cutting SS Fret tangs on bound boards. It uses a SM Dremel adjustable base and a 1-1/4" Dremel cutoff wheel so you get easy fine adjustment and a quick cut. The only downside is the fret gets a bit warm during the cut so I keep a little cup of water on hand to cool it down afterward. It never gets so hot that it discolors the metal but certainly too warm to touch. Works like a champ! Cheers, M |
Author: | Chris Pile [ Thu Jun 23, 2016 1:10 pm ] |
Post subject: | Re: Simple SS Fret tang jig |
Clever. I like it. Could be adapted to work other than fret trimming, too. |
Author: | david farmer [ Thu Jun 23, 2016 1:38 pm ] |
Switching to a small jewelers saw blade would cool things down. Just a thought. |
Author: | Jim Watts [ Thu Jun 23, 2016 3:14 pm ] |
That's a good idea! |
Author: | Colin North [ Thu Jun 23, 2016 3:14 pm ] |
Neat! I likes that. |
Author: | JSDenvir [ Thu Jun 23, 2016 3:24 pm ] |
How come all my jigs look like they were assembled by drunken elves? |
Author: | Jim Watts [ Thu Jun 23, 2016 3:41 pm ] |
JSDenvir wrote: How come all my jigs look like they were assembled by drunken elves? Have you been drinking? |
Author: | Michaeldc [ Thu Jun 23, 2016 3:51 pm ] |
JSDenvir wrote: How come all my jigs look like they were assembled by drunken elves? Because I cheat and use my CNC to make my jigs... |
Author: | david farmer [ Thu Jun 23, 2016 5:03 pm ] |
Only a matter of time before every drunken elf has CNC. |
Author: | meddlingfool [ Thu Jun 23, 2016 5:14 pm ] |
Very nice! |
Author: | BradHall [ Thu Jun 23, 2016 5:32 pm ] |
Great set up. That's exactly what I will need on my current build. Since I don't have a CNC set up, I can use the rosette cutter jig on my Stewmac plunge base to cut the wheel base most of the way. What do you think about a small fence on one side to control fret as you you push it into the wheel? Thanks. |
Author: | printer2 [ Thu Jun 23, 2016 5:36 pm ] |
david farmer wrote: Only a matter of time before every drunken elf has CNC. If only you can get them to load the parts right side up. |
Author: | Michaeldc [ Thu Jun 23, 2016 5:45 pm ] |
BradHall wrote: Great set up. That's exactly what I will need on my current build. Since I don't have a CNC set up, I can use the rosette cutter jig on my Stewmac plunge base to cut the wheel base most of the way. What do you think about a small fence on one side to control fret as you you push it into the wheel? Thanks. Brad, If I'm understanding you, I think the 1/32" wide slot guide is a better way to go than a fence because the fret body is held co-planer with the cutoff wheel. Does that make sense? Best, M |
Author: | BradHall [ Thu Jun 23, 2016 5:48 pm ] |
Is there a slot on your set up? I can't see it in the photo. You're right, a slot would be much better. Thanks. Sent from my iPad using Tapatalk |
Author: | Michaeldc [ Thu Jun 23, 2016 6:05 pm ] |
BradHall wrote: Is there a slot on your set up? I can't see it in the photo. You're right, a slot would be much better. Thanks.
Yup, look closely at the first photo. Sent from my iPad using Tapatalk |
Author: | BradHall [ Thu Jun 23, 2016 6:07 pm ] |
Duh..don't know how I missed the first photo. Thanks again. Sent from my iPad using Tapatalk |
Author: | Imbler [ Thu Jun 23, 2016 6:15 pm ] |
Jim Watts wrote: JSDenvir wrote: How come all my jigs look like they were assembled by drunken elves? Have you been drinking? Or on a slightly more relevant note: Have your elves been drinking? ![]() |
Author: | JSDenvir [ Fri Jun 24, 2016 10:21 am ] |
Well geez, now that you mention it... ![]() |
